1999 Other Oldsmobile Models Cooling fans not coming on
1999 OLDSMOBILE
CKRYSIAK
Engine Cooling problem
1999 Other Oldsmobile Models 6 cyl Front Wheel Drive 106000 miles
The cooling fans on my Olds Intrigue are not coming on.
So far I put 12 VDC to them, motors are working fine.
I checked the 40 amp fuse..OK.
Tested the 2 relays..getting continuity through both of them.
I went and bought a temperature sensor.
The problem is I do not know where it is located!
Any ideas??
Thanks
Carl
Apr 18, 2008 at 12:30 PM
MASTERTECHTIM
  • 4,750 POSTS
the sensor is located on the intake manifold right near the thermostat. (follow upper rad hose to engine and thats the thermostat housing) 2 wires go to is, usually yellow and brown.
Apr 18, 2008 at 1:13 PM
CKRYSIAK
I found the temperature sensor. Everyone has been telling me it is located by the thermostat. The key here is that it is a 3.5 engine. It is located in the block on the back side of the engine about half way down. It is a real bear to get at.
Apr 23, 2008 at 10:13 AM
