1998 Oldsmobile wont start
1998 OLDSMOBILE
JOHNNYW
Electrical problem
1998 Oldsmobile V6 Front Wheel Drive Automatic 118000 miles
Couple of days ago the van was a little difficut to start, as if the battery was going bad. The next day the van would not start. I put a charger on. Battery reads 12.2 volts. When trying to start the lights come on bright but go out when I turn the key. Thanks for any help.
Dec 8, 2007 at 5:55 AM
BOBBY71RIV
[quote:cbdd198120="Johnnyw"]Electrical problem
Couple of days ago the van was a little difficut to start, as if the battery was going bad. The next day the van would not start. I put a charger on. Battery reads 12.2 volts. When trying to start the lights come on bright but go out when I turn the key. Thanks for any help.[/quote:cbdd198120]
I had something close happen to mine. Tighten the battery cables and see if that helps.
Feb 19, 2008 at 3:09 AM
