1998 Olds Silhouette MAJOR Oil leak problem
1998 OLDSMOBILE
OLDSVAN1
I have a 1998 Olds Silhouette 3400cc V6 that has oil spewing from the oil filter. It was running fine and had no leak when I parked it, but the next morning when I cranked it up, oil began spewing from the oil filter. I've changed the filter (3 times) and still have the same result, losing about 1/2 quart in 15 seconds.
Any ideas?
Jan 2, 2007 at 12:49 AM
SERVICE WRITER
  • 9,123 POSTS
What i do know:
The 3.4 motor are common for an intake leak that can cause leakage, oil or coolant consumption.
What I don't know:
If the leak can cause a compression of the oil and forcing it out like it is.
Jan 2, 2007 at 2:24 AM
HYKNRD
  • 59 POSTS
Hi Oldsvan1--
:?: Are you sure you're getting the right replacement filter--same threads, seal? Are you making sure the old seal is removed from the engine when you install the new one?
If all these check out you may want to check your oil pressure. The oil pressure relief valve(if it has one)may be sticking closed causing higher than normal oil pressure. Is the filter actually ruptured?
Jan 9, 2007 at 12:21 PM
SERVICE WRITER
  • 9,123 POSTS
GOOD Point Duane, I assumed it wasn't a fresh lof. Those gaskets can make one look foolish :oops:
Jan 9, 2007 at 12:24 PM
HYKNRD
  • 59 POSTS
Service Writer--
Uhhhh....Thanks,I THINK. What's a fresh lof?
Jan 9, 2007 at 2:13 PM
SERVICE WRITER
  • 9,123 POSTS
[quote:33001ab6f3="hyknrd"]Service Writer--
Uhhhh....Thanks,I THINK. What's a fresh lof?[/quote:33001ab6f3]
:lol: Lube, Oil, Filter
We use a lot of acronyms at work on our program that kick out verbage. But I guess the lube is not relebant anyway :roll:
Jan 9, 2007 at 9:04 PM
HYKNRD
  • 59 POSTS
[quote:d2c13e727f="Service Writer"][quote:d2c13e727f="hyknrd"]Service Writer--
Uhhhh....Thanks,I THINK. What's a fresh lof?[/quote:d2c13e727f]
We use a lot of acronyms at work on our program that kick out verbage. But I guess the lube is not relebant anyway :roll:[/quote:d2c13e727f]
Service Writer--
Thanks. Learn something new every day. Will have to remember that. Great......another acronym.
Jan 11, 2007 at 8:09 AM
