1997 Other Oldsmobile Models coolant outlet leaking
1997 OLDSMOBILE
MICHAEL R.PLUNKETT
Engine Cooling problem
1997 Other Oldsmobile Models 4 cyl Two Wheel Drive Automatic
is there a gasket on the coolant outlet or must I clean it and seal it with gasket cement?
Aug 19, 2008 at 11:23 AM
BLACKOP555
  • 10,386 POSTS
there are no gaskets or cement on upper and lower radiator hoses. make sure your using hose clamps not the basic water pump clamps, they loose their strenght after 1 use.
Aug 19, 2008 at 12:51 PM
