1997 Bravada a/c condensate drain
1997 OLDSMOBILE
VANEATON
It appears that my condensate drain is stopped up because I can hear water sloshing underneath my dash from inside the car. How do I get to the drain line to unstop it?
Oct 26, 2007 at 6:57 AM
MERLIN2021
  • 17,250 POSTS
1 of 2 ways, if you have room to get under the truck were the firewall is on the passenger side you will see the drain on the black fiberglass plenum, use a can of keyboard air and the extension, and blast a few shots into it, or use a piece of wire and run it into the hole just enough to clear it. Or pee the rug back on the passenger side and find the plastic tube, drill a small hole and run wire towards the bottom of the truck...then plug the hole with silicone.
Oct 26, 2007 at 8:11 AM
