96 Achieva, 2.4 twin cam, will start and run 2 seconds then die, must wait a few minutes to get it to start the 2 seconds, will continue to run if I feed it starting fluid, has fuel pump has 48psi on the inline fuel guage, O2 sensor is only code, customer changed ignition module, again ran for a few minutes then back to same 2 second run.
SPONSORED LINKS
Tuesday, April 8th, 2008 AT 12:54 AM
