1996 Other Oldsmobile Models starter
1996 OLDSMOBILE
PYROS_56187
Engine Mechanical problem
1996 Other Oldsmobile Models Front Wheel Drive Automatic
i replaced the starter on my friends car and now when you turn the key all you get is a single click followed by a very soft whiring sound. thinking maybe i missed a connection some where i pulled it back out and double checked everything and then put it back in and its still doing it what could be causing this if you can help i would really appreciate it
Apr 7, 2008 at 12:35 PM
D5NUKE
  • 61 POSTS
It sounds like the starter solinoid is not engaging. If you hear the whirl sound its the motor turning.If the solinoid engages and pushes the gear forward it would crank the engine.sounds like you might have a bad starter from the parts store. I suggest you take it back and have them bench test it. Then get back with me and let me know how it goes.
Apr 7, 2008 at 1:58 PM
