1996 Other Oldsmobile Models oil level sensor 3100 engine
1996 OLDSMOBILE
87,000 MILES • 6 CYL • FWD • AUTOMATIC
JHNATKO
check oil lite same on, oil was ok. changed oil pressure switch, changed oil and filter. ran car about 10 miles normally- no lite. next morning lite on. checked haynes manual, check oil lite is wired to an oil level sensor in the oil pan not the pressure switch. where the halibut is the oil level sensor located? manual doesn't mention it. If I can find it- I can replace it
Jan 9, 2008 at 11:33 AM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Screws into the side of the oil pan.Might want to drain your new oil into a clean container for re-use first, since you just changed it
Jan 10, 2008 at 7:32 AM
