1996 Other Oldsmobile Models
1996 OLDSMOBILE
SPARXX
Transmission problem
1996 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic
Why does my 1996 Oldsmobile Cutlass Supreme jerk somtimes when I accelerate?
Jul 10, 2010 at 7:43 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 10, 2010 at 5:02 PM
