1996 olds aurora
1996 OLDSMOBILE
KSMITH
i am having problems with my aurora. it has a cylinder misfire. i have replaced plugs, wires and ignition coil module and the problem still exist. it seems like it has a bad miss. it has no power at all to run
Apr 28, 2007 at 2:20 PM
2CARPRO JACK
  • 11,533 POSTS
You replaced the module, but what about the coil ? Do you know what cylinder is missing? Verify that there is good (blue) spark at all cylinders. Good compression in all cylinders? Next is the injectors. Do any plugs look wet from gas?
Apr 29, 2007 at 1:45 AM
KSMITH
we have replaced the ignition module and coils. yes the # 8 plug has gas on it. we tested compression on all and it is good
Apr 29, 2007 at 2:08 AM
