1995 Other Oldsmobile Models Help request
EDUARD70
  • 1995 OLDSMOBILE
  • 4 CYL
  • 18,000 MILES
I had a nightmare called Olds Achieva. I have an electrical issue with turn right signal which is not flashing(although is comming on). The turn left signal and warning lights are OK. I checked the right bulbs and all are OK. It could be the flasher, but where it is hide.
Any help is welcome.
Thursday, December 13th, 2007 AT 7:42 PM
JOSHWILCOX26
The flasher fuse is located under dash drivers side. You have to unscrew the panel below the dash and let it hang. There is a second panel u need to unsrew its under that near the steering column. There usually white and plastic. I hope this helps.
Saturday, March 28th, 2009 AT 10:24 AM
