1995 Other Oldsmobile Models code scanner
1995 OLDSMOBILE
71,223 MILES • 6 CYL • 2WD • AUTOMATIC
GRANTORINO54
what code scanner does a 1995 oldsmoble cutless supreme use.
Feb 9, 2010 at 1:35 AM
JDL
  • 16,098 POSTS
welcome to the forum. If your datalink connector looks like the picture below, you may be able to access mil codes without special tools. You place a jumper wire between A & B terminals of the datalink connector. Turn the key just till the dash lites come on, no further, the mil starts flashing, you count the flashes to get the codes. example, a code 21, two quick flashes, slight pause, one flash. It should repeat three times before moving to next code, if there is one.
https://images.2carpros.com/forum/automotive_pictures/170934_cutlass_supreme_1.jpg
Feb 9, 2010 at 2:28 AM
