1995 oldsomobile cutless supeme ls
1995 OLDSMOBILE
JAIME
today i got in my car i begin to drive i noticed it didnt feel as if it at
the boost as it normally does i didnt shut it off for atleast 30 miles i
noticed the battery light on and i noticed that it only came on when i
left off the gas and went off within 3 secd of pushing on the gas i also
noticed that when i came to complete stops it was all it had left to turn
i finally shut it off at my job and it would not crank this was 7 am at
10
sam i went out and it crunk up just great then at 12 i crunk it up drove
it
a couple of miles and it shut off again and i had to get it jumped off i
did not make it 4 miles up the road before it shut off causing the rpm to
jump back and forth asnd the sterring will to seem to be getting locked
and once again i had it jumped off only to make it about 2 miles and the
jump off and all the other repeats was completed and i was finally home
now my car is parked[/b]
Mar 17, 2006 at 11:42 AM
PEPPERMRJ
  • 1,158 POSTS
Did you check the serpentine belt and its tensioner?
Sounds like it is loose.
Good luck and let us know. :)
Try reposting in the GM section of the forum for more results.
Mar 17, 2006 at 12:06 PM
JPAM
  • 307 POSTS
bump** moved to GM forum
Mar 17, 2006 at 5:39 PM
