I'm not losing oil, or any other fluids that I know of either. I do seem to lose more radiator fluid though if I take longer trips.
Any easy fixes? Thanks for the help.
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the coolant loss and cold-start noise investigated together, including a cooling-system leak assessment. Report that the noise persisted during the earlier belt-off test without repeating that test as a routine procedure.
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis. HELLA: Cooling-system checks https://www.hella.com/techworld/ae/technical/car-cooling-system/cooling-system-check/ General temperature, circulation and leak checks; use the actual vehicle procedure.
1995 Olds Cutlass Supreme engine noise first minute or two
A 1995 Cutlass Supreme developed a brief cold-start clicking or sputtering noise after radiator replacement and continued losing coolant without an obvious external leak. The owner said the noise persisted with the accessory belt removed and later lasted longer.
Reported outcome: No leak source or cause of the noise was confirmed.
The absence of visible fluid mixing or exhaust smoke did not establish a diagnosis. The lifter and head-gasket suggestions were not supported by reported test results.
