HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Other
Engine Cooling
Water Pump
Leak
1995 olds Aurora 156000 water pump leaking
BRAD STACY
MEMBER
1995 OLDSMOBILE
How do you replace the water pump on a 1995 olds aurora
Tuesday, June 27th, 2006 AT 7:38 PM
MOZEZ
MEMBER
Jst had mine done. It cost a lot of money. Better hope it ain't your water pump housing as well. I had to replace it all.
If you gone do it yourself. You are going to need a special tool
SPONSORED LINKS
Tuesday, February 27th, 2007 AT 6:02 PM
Please
login
or
register
to post a reply.
Related Water Pump Leak Content
Water Pump Housing Leak In 1995 Achieva
Hi, Everyone I'm New Here And My 95 Achieva Has Been Having Some Leaking Isuses. My Mechanic Said That The Water Pump Itself Is Fine But It...
Asked by
chnike112
1 ANSWER
1995
OLDSMOBILE OTHER
1996 Oldsmobile Changing Water Pump
Trying To Change Water Pump On '96 Olds 88 Got Most Of It Pretty Easy But Then The Last Bolt Is Just On The Edge Of Another Pully. Need Help...
Asked by
bseiwert
1 ANSWER
1996
OLDSMOBILE OTHER
Water Pump Replacement?
1998 Olds Aurora 4.0 L. It Seems Easy Enough To Replace A Leaking Water Pump, However Someone Mentioned Special Tools? Any Advice And...
Asked by
JeffB
OLDSMOBILE OTHER
Water Pump Oldsmobile 1992 Royale 88 Ls, 100k Miles, 3...
How Do You Remove The Water Pump? The Motor Mount Is In Front Of Two Long Bolts On The Water Pump. The Top Bolt Is Accessible But The Bottom...
Asked by
oldmike1
1 ANSWER
1992
OLDSMOBILE OTHER
Oldsmobile Water In A.i.r. Pump
I Have A 2001 Olds Intrigue That I Heard A Water Bubbling Sound From The Left Front Engine. Took It To The Dealer And They Replace The A.I....
Asked by
rosebud1988
1 ANSWER
OLDSMOBILE OTHER
VIEW MORE
SPONSORED LINKS
Coolant Leak Repair
Cooling System Pressure Test
Cooling System Pressure Test For Leaks
Online car repair manuals
