1994 Other Oldsmobile Models belt noise
1994 OLDSMOBILE
159,000 MILES • 6 CYL • FWD • AUTOMATIC
KCLEAF
the noise comming from the belt sounds like tin rubbing against something the car has been sitting for afew months could this be a build up that just has to wear off?
Apr 4, 2008 at 8:44 AM
MASTERTECHTIM
  • 4,750 POSTS
no. if you remove the belt and slowly spin each pulley, you will find one that has a bad bearing in it and needs to be replaced.
Apr 4, 2008 at 10:29 AM
