1994 Other Oldsmobile Models 0 compression on #2 piston
1994 OLDSMOBILE
LETSC
Engine problem
1994 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic 70k miles
I had a miss and a vibration found the miss to be #2 cylinder did compression test oh god "0" that is ZERO and there are no noises and no oil on plug when you run it plug out no oil there is a little carbon on the plug..not sure what could be>>>new engine?? new heads ??will remove value cover and look at lifters >>can a valve be open and not hit the piston???
thanks Bill MClary
Dec 25, 2007 at 11:30 AM
SERVICE WRITER
  • 9,123 POSTS
Need model and engine size.
Try squirting 3 blasts of motor oil into the cylinder and recheck it.
If excesive fuel was in there it may have washed down the oil.
Dec 25, 2007 at 12:01 PM
LETSC
[quote:b529b65db1="Service Writer"]Need model and engine size.
If excesive fuel was in there it may have washed down the oil.[/quote:b529b65db1]
Dec 26, 2007 at 12:22 PM
