1993 Other Oldsmobile Models Steering Rack or Pump Problem
1993 OLDSMOBILE
193,000 MILES • 4 CYL • FWD • AUTOMATIC
REWIRE2000
When I turn to the right or left (especially when it's cold) the steering system kicks and wines (not the belt). The belt looks fine with good tension. The power steering pump and steering rack cost about the same. Is there a way to determine which is at fault?
May 9, 2008 at 12:32 PM
MASTERTECHTIM
  • 4,750 POSTS
usually its the rack when it happens cold, also it seems to be the rack because you are hearing the wine which tells me the pump is working. replace the rack
May 9, 2008 at 12:42 PM
LEGITIMATE007
  • 5,121 POSTS
mastertechtim is right, but I had this problem too in one of my cars, and to my surprise, I needed a front end allignment, let me explain. the turn ratio was way off causing my car to make a whine like your describing. when they alligned it correctly the whining ceased. the rack had to move farther back and forth than normal causing it to whine. what I'm saying is give it a try, you may be able to get a lot more time out of your rack before having to change it out
May 9, 2008 at 2:48 PM
