1993 Other Oldsmobile Models engine stalls
ROND5155
  • 1993 OLDSMOBILE
  • 6 CYL
  • FWD
  • 63,702 MILES
I have a 1993 Olds Cutlass Ciera, front wheel drive and a "N" engine code. Most of the time it will drive really great. Sometimes when you pull up to a stop light and the engine dies. You restart and when you put it in gear again, it immediately dies again. Usually to get going you have to acellerate heavy and throw it into drive and sometimes it will run and other times it will die. I took it to a mechanic and he couldn't find anything wrong with it and it didn't act up on him. It doesn't act up all of the time, just some times. Can you please help me to try and figure out what might be causing this?
Sunday, July 20th, 2008 AT 2:32 PM
MERLIN2021
  • 17,250 POSTS
Intermittent problems are tough, but is thre Service engine soon light on?
Sunday, July 20th, 2008 AT 3:29 PM
ROND5155
No, the service engine soon light is not on.
Sunday, July 20th, 2008 AT 6:20 PM
MERLIN2021
  • 17,250 POSTS
Check the EGR for sticking open.
Monday, July 21st, 2008 AT 2:39 AM
ROND5155
How do I check the EGR to see if it is sticking open?
Monday, July 21st, 2008 AT 7:25 AM
MERLIN2021
  • 17,250 POSTS
Start engine. Using Tech 1 scan tester or a tester capable of cycling ECM output devices, select miscellaneous tests. With engine idling, RPM should drop and engine should idle rough as each solenoid is energized. If system operates as specified, EGR valve is functioning correctly.
Monday, July 21st, 2008 AT 5:51 PM
