1993 Other Oldsmobile Models Coolant/ Antifreeze leaking
1993 OLDSMOBILE
98,000 MILES • 6 CYL • FWD • AUTOMATIC
SPAZZBRINK
I have a 1993 Olds Cutlass Supreme with a 3.1. I'm having a problem with my coolant leaking. When i open the hood about 3 weeks ago from it overheating i noticed the coolant was full but also noticed that there was coolant leaking on to the serpentine belt. I think it is coming from the water pump but I'm not sure. Do you think it could be the whole pump or just a gasket, and how much does a repair like this normally cost?
Dec 30, 2009 at 2:43 AM
HMAC300
  • 48,601 POSTS
this needs to be properly diagnosed as there were problems with intake manifold gaskets. If it's gaskets it can be about $800 to fix it, but it coul be a waterpump as well. Apro can pressure check he system to see where it can bee seen where it is leaking.......
Jan 22, 2010 at 6:34 AM
