1993 Other Oldsmobile Models Code 56 QDM Problem
1993 OLDSMOBILE
81,000 MILES • 6 CYL • FWD • AUTOMATIC
PERSONALMECH1
I just bought a 1993 Olds Ninty Eight for my daughters first car. The engine idles a bit rough, but is random. It is Super Charged. I am getting the code "56 QDM Problem". Can you help me out with the definition of the code and possible areas to test or inspect? Much Thanks, Robert Holmes
Apr 5, 2008 at 12:46 PM
MASTERTECHTIM
  • 4,750 POSTS
code sets if egr solenoid is bad or the transmission torque converter clutch solenoid is bad. also check resistance across coil towers and if they are not equal then replace
Apr 5, 2008 at 12:55 PM
