1993 Olds Regency Elite Heater Core
1993 OLDSMOBILE
DAVIDANDERSON
I have two questions related to repacing the heater core:
1. How do you get the hoses off in such a cramped space?
2. How to you access the core in the HVAC system?
Jul 21, 2007 at 7:49 AM
DEK
Replacing a heater core on that Oldsmobile is an hour job....and the clamps on the firewall are the hardest part. Remove the screws from the underdash sound baffle on the passenger side and pull the baffle down. Look straight up and there should be several screws holding a small panel door together. Remove the panel and the heater core will be right there. After you've removed the clamps at the firewall and removed the screws to the heater core it should slip right out.
Jul 26, 2007 at 1:27 PM
