1993 olds bravada
1993 OLDSMOBILE
GOOFY57
does anyone know why the guages do not work all the time? the speed ometer works all the time, but the rest only works every now & then
thanks
Feb 15, 2006 at 4:26 AM
FISHERMAN
  • 937 POSTS
that happens quite often check for loose connector behind the dashboard, its hard to reach but if you can`t do it, you have to dissasemble the dashboard from the front side, and that takes more challenge to do it.
Feb 15, 2006 at 4:40 AM
GOOFY57
thanks I will give it a try
Feb 15, 2006 at 6:33 AM
GOOFY57
checked connections all ok, even removed it & reinstalled it & still not working. anymore suggestions.
thanks
Feb 16, 2006 at 3:39 AM
Discussion summary
1993 olds bravada
1993 Olds Bravada with intermittent instrument-cluster operation: the speedometer works continuously while the other gauges only work occasionally. The poster was advised to check for a loose connector, then inspected connectors and removed/reinstalled the cluster; connections appeared OK but the problem persisted.
Reported outcome: After checking and reconnecting the cluster and even removing and reinstalling it, the poster reports the other gauges still do not work; no fix reported.
Read the original discussion
