1993 olds bravada
1993 OLDSMOBILE
GOOFY57
does anyone know why the guages do not work all the time? the speed ometer works all the time, but the rest only works every now & then
thanks
Feb 15, 2006 at 4:26 AM
FISHERMAN
  • 937 POSTS
that happens quite often check for loose connector behind the dashboard, its hard to reach but if you can`t do it, you have to dissasemble the dashboard from the front side, and that takes more challenge to do it.
Feb 15, 2006 at 4:40 AM
GOOFY57
thanks I will give it a try
Feb 15, 2006 at 6:33 AM
GOOFY57
checked connections all ok, even removed it & reinstalled it & still not working. anymore suggestions.
thanks
Feb 16, 2006 at 3:39 AM
