1993 Bravada Cluster Panel
1993 OLDSMOBILE
CROWBAR
Have 1993 Olds Bravada 4.3 Vortex 163,000 miles all gauges on cluster panel does not work odometer and speedometer work. Mechanic removed cluster panel looked ok cluster panel work for one week quit again. Any idea loose wire/burnt panel?
Thanks
Apr 30, 2007 at 3:19 PM
  • 75,988 POSTS
[quote:4a2167746f="crowbar"]Have 1993 Olds Bravada 4.3 Vortex 163,000 miles all gauges on cluster panel does not work odometer and speedometer work. Mechanic removed cluster panel looked ok cluster panel work for one week quit again. Any idea loose wire/burnt panel?
Thanks[/quote:4a2167746f]
Could be a ground circuit problem.
May 1, 2007 at 11:41 AM
CROWBAR
[quote:0c7c6f305d="rasmataz"][quote:0c7c6f305d="crowbar"]Have 1993 Olds Bravada 4.3 Vortex 163,000 miles all gauges on cluster panel does not work odometer and speedometer work. Mechanic removed cluster panel looked ok cluster panel work for one week quit again. Any idea loose wire/burnt panel?
Thanks[/quote:0c7c6f305d]
Could be a ground circuit problem.[/quote:0c7c6f305d]
Rasmataz, thanks for the quick response sounds like one needs to be an avionics expert any hint on where I might start. Would be nice to fix daughter is rough on cars without gauges guess who drives it.
Thanks
May 1, 2007 at 2:57 PM
