I'll be driving my car and then out of the blue it will stall and not start back up. I'll let it sit for a little while(10-20 minutes) and then it starts. The last time it happened I felt like a pop then the Check Engine light went on then it stalled out then I let it sit then it started back up.
SPONSORED LINKS
Thursday, October 9th, 2008 AT 4:54 PM
MERLIN2021
MECHANIC
Usually ends up as a bad igniton module, try taking it out, go to a parts store and have them test it. Is the check engine light on?
Thursday, October 9th, 2008 AT 5:25 PM
LIONHART40
MEMBER
I am having the same problem with my 92 oldsmobile ciera. I checked the ignition module and it checked out as being good.
SPONSORED LINKS
Monday, November 3rd, 2008 AT 7:59 PM
MERLIN2021
MECHANIC
If the ignition module is checked and found to be good, you must scan for codes, check PCM power and grounds, and loose connections, then check fuel pressure. Go here and checkout our video.
