1992 Other Oldsmobile Models over heating
1992 OLDSMOBILE
JIM STEVENSON
Engine Cooling problem
1992 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic
when the car is first driven in the day it overheats even after the level is checked in the radiator. the fluid is being pushed out to the recovery tank. i have to let the engine cool, take off the radiator cap and let it drain back into the radiator. after that the car runs fine all day. i have changed the thermostat and radiator cap. two weeks ago it overheated real bad. i had a coolent line break. i repaired the problem and this one came up. im lost on this one. thanks for any help.
May 4, 2008 at 12:56 AM
2CARPRO JACK
  • 11,533 POSTS
Have it tested for a blown head gasket. It may have happened when the line broke, now the engine is creating too much pressure in the cooling system
May 4, 2008 at 1:14 AM
