1992 Other Oldsmobile Models Help Needed...
1992 OLDSMOBILE
JBRADNDHM
1992 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic
Hello, I own a 1992 oldsmobile cutlass ciera and I don't have an owners manual... I replaced the gas tank and fuel pump recently and now I'm not getting any power to the fuel pump. What are the possible causes and how can they be rectified?
Mar 24, 2010 at 9:39 AM
HMAC300
  • 48,601 POSTS
the wires in the fuel tank going to the pump are very small. see if you have power going to the taank on the outside and if you do your trouble is on the outside. also check your fuses and relay..
May 22, 2010 at 10:59 AM
