1992 Other Oldsmobile Models belt tentioner
1992 OLDSMOBILE
148,000 MILES • 6 CYL • FWD • AUTOMATIC
KEVIN W
when I give car a little gas and release the tentioner hangs up and makes a clicking noise not sure if it's pulley or tentioner assembly
Feb 7, 2010 at 2:06 PM
HMAC300
  • 48,601 POSTS
if it does that, the beraing is going bad. The tensioner comes as an assembly and is fairly easy to replace. You may as well change the belt too and if you forget how it goes (belt) , go to popular site links on 2carpros here and you can find a diagram ofit here under belt routing diagrams.
Feb 22, 2010 at 2:37 AM
