1992 Oldsmobile Blower Fan not Working.
1992 OLDSMOBILE
CARFUN
Hello There.
I have a 1992 Oldsmobile Eighty-Eight Royale LS.
My problem is i can't seem to get the blower fan to work. I think it might be a loose wire because about 4 months ago it would come on and go off every so often but not anymore. My car has the Electric climate control and all the buttons work and when i press the fan speed button on the steering wheel as on the control box it will not come on. I tryed disconnecting the climate control box and reconnecting it but that didn't do anything. If it's a fuse or relay problem how would i go about fixing it. Unforuntly i'm just the average joe so you will have to bear with me. Thanks for any answers.
Oct 17, 2007 at 5:06 PM
Try direct power to the blower motor if it comes on check the resistor pack, then to the control switch.
Oct 17, 2007 at 11:22 PM
CARFUN
thanks rasmataz for your reply. I found out the problem was a shot blower fan. Where i live we have place called Piston Ring they wanted $80 CDN for a new one so i decided to get a used one which was $50 dollars :) and the used one works like a charm. I recommend anyone else out there that has the same car as me to use a multimeter on your blower fan connection as this was the problem for me.
Oct 20, 2007 at 1:39 PM
