1992 Olds 88 Royale
1992 OLDSMOBILE
JBALAS02
I noticed today that my car has started leaking coolant. I had to get to work, so I put some coolant in the reservoir before leaving for work. I get to my destination and decide to look under the car to see if it is still leaking. It is. I had my water pump replaced last year, and it doesn't look like it is leaking from the reservoir. Is it possible it could be a bad hose, or the transaxle coolant line needs to be replaced? My car is a 1992 Olds 88 Royale.
Jul 3, 2006 at 2:41 AM
CSTOLIKER
  • 6 POSTS
If the transaxle coolant line was leaking it would leak transmition fluid and not coolent. I would start by looking the the heater core lines.
Jul 18, 2006 at 10:01 AM
XOWEY
  • 113 POSTS
the best way to locate a coolant leak is visually, you have to start by determining what general area the coolant is leaking from. go to the highest point that you find wet and you'll be getting close. :wink:
Jul 19, 2006 at 1:18 AM
ZOMBIE1243
  • 6 POSTS
you can also go to napa a purchase a coolant pressure tester that is the easiest way to find a leak.... :D
Jul 20, 2006 at 7:12 AM
