1991 Other Oldsmobile Models IT IDLES RUFF
1991 OLDSMOBILE
TROUP FAMILY
Shakes or Wobbles problem
1991 Other Oldsmobile Models 4 cyl Two Wheel Drive Automatic
Just asking to see if i got a vacume leak, or sparkplug problems, or a fuel filter going out
Jul 7, 2010 at 12:49 PM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 7, 2010 at 5:23 PM
