1991 Other Oldsmobile Models Fuel Pump and relay
1991 OLDSMOBILE
JDOUGHERTY11599
Other Category problem
1991 Other Oldsmobile Models 6 cyl Wheel Drive Type unknown Automatic 111000 miles
Need to check fuel relay and reset? Not sure if the fuel pump is bad or not.
Dec 31, 2007 at 4:58 AM
  • 75,988 POSTS
When you turn key to On -do you hear the fuel pump come On ?-if so check the fuel pressure-if not inspect and test for power
Dec 31, 2007 at 8:28 AM
