1991 Other Oldsmobile Models Car quits
DLKMULE
  • 1991 OLDSMOBILE
  • V8
  • FWD
  • 134,000 MILES
My 91 Olds Regency 98 runs extremely smooth until all of a sudden it will quit. If you leave it set for 30 minutes or so, it will start right up and run great again until it decides to quit again. I ran into this problem with a 92 Buick Park Ave and it was some sort of sensor on the engine (not an oxygen sensor), what is that sensor called?
Friday, October 3rd, 2008 AT 9:20 AM
  • 109,867 POSTS
Hi:
There are many sensors. Take your pick: Mass Air flow sensor, MAP sensor, Throttle position sensor, Crankshaft sensor, Cam sensor.
Have you had the computer scanned for codes? To me it sounds like a bad ignition module. It is the small black square item mounted in the bottom of the distributor.
Let me know if this helps.
Saturday, December 20th, 2008 AT 9:52 PM
