1991 Oldsmobile Cutlass Ciera Mileage Approx. 150,000
JESSICANT
  • 1991 OLDSMOBILE
I just recently had my spark plugs changed because my car was stalling out quite a bit. Well, I took it for a test drive after spark plugs were installed and it stalled out three times! My "service engine soon" light stays on while driving-and my speedometer works for a second and then goes back out. When speedometer works engine light goes out. It stalls mostly when I stop. Sometimes it stalls as i'm driving along as if someone has taken the key out. No warning of the stall-just shuts off.I'm so frustrated-i've had my fuel filter replaced and of course the spark plugs. Don't know what it could be. Please any suggestions would be great! Thanx, jessica
Sunday, March 19th, 2006 AT 4:11 PM
JPAM
  • 307 POSTS
Bump** moved to GM forum
Wednesday, March 22nd, 2006 AT 2:36 AM
RUXBAN
  • 5 POSTS
On the drivers side of your car, there is a computer connection. It may be under a small panel of some sort, or up above your brake pedal. Simply find this "connection" and jump termail A to terminal B.
Take a simple paper clip, and bend it. Stick one end in the termail hole A (upper left hand corner of the connection), to terminal B, (the one next to it). Make sure you stick the paper clip in far enough to stick by itself.
The Service engine soon light will begin to flash. It will read a code 12 (flash. Pause. Flash flash). It will flash this code 3X. This code tells you that your vechical is communicating with you.
After your initial code 12. Addition codes will read out if there is something wrong, which there probably is.
Example: Code 23-- (flash flash. Pause. Flash flash flash)
Example: Code 41-- (flash flash flash flash. Pause. Flash)
No codes end is 0 so there is no concern on how to read those. All codes will Flash 3X.
You may have several codes at one time. Write them down.
Go down to your local, Napa, Checker, Kragen, eautopartstore, Car Quest ect, and pick up a Chilton manual or Haynes.
**I perfer the Chilton** They are $20, and are a great investment.
Simply look your codes up in your Chilton under the Troubleshooting codes section, and go from there.
*****Screw the profession code reader! Use a paper clip****
Good luck.
Wednesday, March 22nd, 2006 AT 11:41 PM
