1991 Oldmobile Cutlass Supreme Signal Probelms
1991 OLDSMOBILE
HONDA_MASTER
  • 6 POSTS
I have a 1991 Oldsmobile Cutlass Supreme with 183,000 miles on it. I've been having problems with my turn signals. When I go to turn either right or left the signal blinks very slowly. I sometimes have to hold it in a certain spot for it to work at all. Then after I was messing around with it for awhile I started to smell something electrical burning, so I stopped and shut the ignition off. Any ideas on what the problem could be. Any help would be very much appreciated. Thanks
Oct 1, 2007 at 12:50 PM
BMRFIXIT
  • 19,053 POSTS
[quote:597d333a1d="Honda_master"]I have a 1991 Oldsmobile Cutlass Supreme with 183,000 miles on it. I've been having problems with my turn signals. When I go to turn either right or left the signal blinks very slowly. I sometimes have to hold it in a certain spot for it to work at all. Then after I was messing around with it for awhile I started to smell something electrical burning, so I stopped and shut the ignition off. Any ideas on what the problem could be. Any help would be very much appreciated. Thanks[/quote:597d333a1d]++++
YOUR SIGNAL SWITCH is no good
You need it replaced
You have to remove the steering wheel and plate under it to reach the switch.
Good luck
Oct 1, 2007 at 12:57 PM
HONDA_MASTER
  • 6 POSTS
[quote:128eaa7264="BMRFIXIT"][quote:128eaa7264="Honda_master"]I have a 1991 Oldsmobile Cutlass Supreme with 183,000 miles on it. I've been having problems with my turn signals. When I go to turn either right or left the signal blinks very slowly. I sometimes have to hold it in a certain spot for it to work at all. Then after I was messing around with it for awhile I started to smell something electrical burning, so I stopped and shut the ignition off. Any ideas on what the problem could be. Any help would be very much appreciated. Thanks[/quote:128eaa7264]++++
Good luck[/quote:128eaa7264]
Do you think I might have made things worse by messing around with it? The burning electrical smell didn't seem to good.
Oct 1, 2007 at 1:07 PM
BMRFIXIT
  • 19,053 POSTS
[quote:14cee1516e="Honda_master"][quote:14cee1516e="BMRFIXIT"][quote:14cee1516e="Honda_master"]I have a 1991 Oldsmobile Cutlass Supreme with 183,000 miles on it. I've been having problems with my turn signals. When I go to turn either right or left the signal blinks very slowly. I sometimes have to hold it in a certain spot for it to work at all. Then after I was messing around with it for awhile I started to smell something electrical burning, so I stopped and shut the ignition off. Any ideas on what the problem could be. Any help would be very much appreciated. Thanks[/quote:14cee1516e]++++
Good luck[/quote:14cee1516e]
Do you think I might have made things worse by messing around with it? The burning electrical smell didn't seem to good.[/quote:14cee1516e]
no
they become loose on the inside
have it replace asap!
Oct 2, 2007 at 11:11 AM
