1990 Olds 88 Royale wierd vacuum pump keeps running.
1990 OLDSMOBILE
ROUTE66KICKS
I am helping a friend on a 1990 Oldsmobile 88 Royale with 96,000 miles. The problem is a small vacuum pump looking thing on the driver's side front wheel well in the engine compartment. It seems to run even when the car is off and may have kept the car from starting or a least ran the battery down. We disconnected it and all seems fine. What did we do and is it important? JKW
Jul 29, 2007 at 1:38 PM
CLY
  • 308 POSTS
My first guess would be that it is a level-ride compressor that you unpluged. The compressor supplies air to the rear shocks to level the car when it is loaded. It wont cause any problems if you leave it unpluged except the ride maybe a bit bouncy...
Cly
Jul 29, 2007 at 10:06 PM
ROUTE66KICKS
Thanks for the excellent help! This sounds pretty reasonable and most of all non-damaging.
JKW
Jul 31, 2007 at 11:00 AM
