1989 Other Oldsmobile Models will not hold a charge
1989 OLDSMOBILE
MAMABIGBUCKS
Engine problem
1989 Other Oldsmobile Models Engine Size unknown Wheel Drive Type unknown Automatic 120000 miles
Not sure what to do next, Replaced battery, new battery cables, new sparkplugs & wires, alternator passed check at auto store. Able to jump vehilce but it will not hold a charge. PLEASE HELP ME!!
Dec 20, 2007 at 7:31 AM
  • 31,937 POSTS
Hi there,
Check for battery voltage at large terminal on alternator, No voltage, problem between battery and alternator, Charge battery and load test, this will give true indication at to battery condition, (new cheap batteries often fail this test) Remove battery Pos cable, hook up Amp meter between battery Pos and cable, with key out and doors closed there should be only about .1 -.2 Amps, anymore and there is a current draw that will be causing the battery to go flat.
Mark (mhpautos)
Dec 20, 2007 at 9:07 PM
KNOBBY
  • 37 POSTS
you have a blown cluster fuse it supplys voltage to alt check all fuses
Dec 20, 2007 at 10:41 PM
