1989 Other Oldsmobile Models door locks,power seats and rear
1989 OLDSMOBILE
27,739 MILES • 6 CYL • FWD • AUTOMATIC
CLYDELS
  • 5 POSTS
All the door locks, rear defrost and power seats went out at the same time. I checked the fuses and replaced the relay switch behind the glove box that was clicking when we tried to lock the doors, but that did no good. I saw something about a fuseable link in the engine except, if that link was bad why would the relay behind the glove box still click? If it can be the fusable link in the engine, where would it be found in the 3800 engine? thanks
Sep 13, 2008 at 5:19 AM
MERLIN2021
  • 17,250 POSTS
What model is this? I cant look up anything on an "other" model.
Sep 13, 2008 at 9:23 AM
CLYDELS
  • 5 POSTS
1989 olds 98 regency broham
Sep 14, 2008 at 10:45 AM
MERLIN2021
  • 17,250 POSTS
At the center of the firewall, under the hood there is a fusible link on the positive junction block, check the rust colored one, give it a slight tug, if it stretches, it burned out, this controls your circuit breaker type fuses, # 3, and 4 on the fuse box, and they are for your blown circuits.
Sep 15, 2008 at 12:28 AM
