1988 Other Oldsmobile Models HOW TO PUT IN A NEW STARTER.
1988 OLDSMOBILE
149,000 MILES • 6 CYL • FWD • AUTOMATIC
DSPICER3
MEMBER
1 POST
TRY TO START CAR TURNED THE KEY ON NOTHING. JUMP THE SELENOID ON THE STARTER CAR THEN STARTED NEED TO KNOW HOW TO PUT IN NEW STARTER AND SELENOID.
Feb 18, 2008 at 6:43 PM
MERLIN2021
✓Experienced Mechanic
Remove the negative(-) battery cable, then remove the wires at the starter, remove the two bolts holding the starter, be careful the starter is HEAVY! use caution removing the last bolt. Install is the reverse of the proceedure!
