1988 Other Oldsmobile Models fuel pump
1988 OLDSMOBILE
14,000 MILES • 4 CYL • FWD • AUTOMATIC
SLINGSHOT000
when i turn key overi hear no fuel pump and car wont start,, is there a fuse or relay or is pump bad
Jan 25, 2008 at 1:40 AM
M.SEXTON
  • 8 POSTS
A QUICK CHECK TO SEE IF YOUR PUMP IS WORKING,LOOK BY YOUR BATTERY,YOU SHOULD FIND A GREEN PLUG THAT GOES NOWHERE. THIS IS A HOT WIRE TO THE PUMP,RUN A JUMPER WIRE FROM THE HOT SIDE OF YOUR BATTERY TO THIS WIRE, THE PUMP SHOULD RUN,IF IT DOES, CHECK YOUR FUSES OR RELAY UNDER THE DASH, IF NOT THE PUMP IS BAD.
Feb 11, 2008 at 3:18 PM
