1988 Other Oldsmobile Models exterior lights
1988 OLDSMOBILE
230,000 MILES • 6 CYL • FWD • AUTOMATIC
RAYBO100
  • 6 POSTS
My 1988 delta 88 royasl brougham has opera lights on the door posts I can trace the wire into a large harness going towards the front of the car and lose it inthe harness, as the opra lights are not lighting up I am assuming it is a burnt out bulb and this is the fiber optic cable (same as the light around the keyhole ) Question -where is the bulb located manual does not even id the opera lights, I have looked many places but cannot find it (both sides of cars lights are out)
Feb 22, 2008 at 9:21 PM
2CARPRO JACK
  • 11,533 POSTS
Go here
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
full wiring diagram and locator for all fuses an accesories
Feb 22, 2008 at 11:48 PM
RAYBO100
  • 6 POSTS
I have electrical diagrams from chiltons it has every wire in it but the wires for the opera lights and key holes
Any wiring diagram I have seen is a schematic and it does not say where it is physically located in the car so I would think this is problably the same
Mar 1, 2008 at 6:21 AM
2CARPRO JACK
  • 11,533 POSTS
It uses a solid state inverter (electro-luminescent) my diagram has it, but I cant finda location anywhere in the locator.Closest I have seen is the inverter for the instrument cluster, It may be the same.It is under the right side of the dash above the glove box.
Mar 1, 2008 at 11:23 PM
