1986 Other Oldsmobile Models cutlass 442 blower not working
1986 OLDSMOBILE
JMAC636
Electrical problem
1986 Other Oldsmobile Models V8 Two Wheel Drive Automatic 91k miles
I have a problem with the a/c and heat blower not working on the high position. I replaced the high speed relay under hood and checked the resistor in the evaporator container. I also swapped the selector in the dash with another one and still no high speed. I'm thinking its wiring but not sure. It's hard to troubleshoot because you can't leave the selector plugged in and access the wiring to check voltage. Any suggestions would be appreciated.
Apr 2, 2008 at 1:45 AM
2CARPRO JACK
  • 11,533 POSTS
With the switch in Hi position, test for 12 volts at the orange wire on the resistor.If it has it, the same should be at the blower, if not test at the switch for 12 out of the switch at the orange wire.If ok, test continuity between the switch and resistor, then motor orange wire
Apr 2, 2008 at 4:31 AM
