1984 Other Oldsmobile Models Pollution Pump
1984 OLDSMOBILE
100,000 MILES • V8 • 2WD • AUTOMATIC
REDLIGHTRACER11
I want to remove the smog pump on my car. Does it just consist of the new belt size and If I chose take the pump out? or are there lines that must be removed from the block or any computer changes? thanks. Also intersted in removing ac compressor. Same principle?
May 14, 2008 at 11:39 AM
MASTERTECHTIM
  • 4,750 POSTS
air pump can just be removed if you have to. same with the ac compressor, just take off the belt
May 14, 2008 at 12:57 PM
