1983 Other Oldsmobile Models Blac smoke from engine when it
1983 OLDSMOBILE
63,678 MILES • V8 • 2WD • AUTOMATIC
BIGMON
car has only 63k miles . when you start it in the mornings black smoke comes out the tail pipe, runs very rough until it is warm. once it is warm up runs like a new car. Is the the carbuerator too rich or what, I put new plugs,wires,rotor and still have the same problem. help me if you can.
Apr 17, 2008 at 4:55 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it may have a sticky or mis-adjusted choke. Try cleaning the choke assembly with carb cleaner then spray it with a little WD-40 to lube it all. If that doesnt help, you may need to take it to a shop to have it adjusted.
Apr 17, 2008 at 6:17 AM
