1982 oldsmobile 98
1982 OLDSMOBILE
JAMES1982
I have a 1982 oldsmobile 98. I keep hearing that the vehicle has valve problems but with no leak I don't believe it. I have problems when I accelerate that I didn't until someone looked at the vacuum line configuration. I'm wondering what to look at because the car seems to backfire and have a tough time accelerating as though fuel is not reaching the carb fast enough.
Apr 16, 2006 at 2:04 AM
LOSONE
  • 1,616 POSTS
If the oil fill pipe for the engine is in the front and not on the valve cover you have a 307 olds engine. It is one of the best engines made with rollar rockers and a bullet proof bottom end.
I doubt that you have a valve problem but you have a carburator problem. The back fire is from a lean mixture from the feedback carb. It takes an "old hand" mechanic like me to be able to repair it as the carb is computer controlled. I suggest you get someone with a scanner who can check the system. You are looking for a dwell of 30 degrees on the carb. You also need to be in computer "open loop" for eveything to work right.
To some it is a complicated but it shouldn't be too hard to fix if you have a tech that knows that old Rochester Quadra Jet feed back system.. Good Luck
Apr 16, 2006 at 2:15 AM
