1981 olds.
1981 OLDSMOBILE
COWJAWONE
  • 6 POSTS
when i put my turn signals they just stay solid, they don't blink. If any answers please let me know.thanks
Jan 12, 2006 at 5:33 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Record which exterior lamps illuminate on each side and give that information to the repairer when requesting diagnosis.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
BAM878S
Try checking your bulbs. If that doesn't help check your fusebox to see if you haven't blown a fuse.
Jan 12, 2006 at 5:39 PM
OLDS89
We recently purchased a 1989 olds delta 88 great car only 70k original miles. There is something wrong with the elctrial or something. When I step on the brake the volume on the stereo goes up and down the gas gauge will go all the way from 1/2 tank to empty in 2 secs. the other day i was tapping the petals gas and brake the stereo volume was gong all the way up then all the way down. I seems to be posessed or something any ideas.
Jan 15, 2006 at 1:56 AM
Discussion summary
1981 olds.
The owner of a 1981 Oldsmobile reported that the turn signals illuminated steadily instead of flashing.
Reported outcome: No test results or successful repair were reported.
Replies suggested bulbs and fuses without identifying the fault. A later post concerns a different, 1989 vehicle with unrelated electrical symptoms.
Read the original discussion
