1994 Oldsmobile LSS idle problem
1994 OLDSMOBILE LSS
142,000 MILES • 6 CYL • FWD • AUTOMATIC
OLDSMOBILE88
  • 12 POSTS
hi car pros.. i have a 94 oldsmobile 88 royal lss that has a little mis to the engine..it is more noticable at a idle in park.. and when acclerating you can see the rmp needle bouncing slightly. but cant feel it in the car. but you can hear it in the engine..i have replaced all three coils. the board the coils are on. forgot what the was called.um plugs, wires,fuel pump,both fuel filters,mass air flow sencor,o2 sensor..none of that helped.and checked for crack hoses and all check out good...o and i put a egr valve on it but it didnt help so i took it back and got my money. what do you think my problem is?
Nov 7, 2010 at 3:32 PM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Maybe a vacuum leak, hard to tell, without something to point in the right direction? Can you look at fuel trims?
Nov 7, 2010 at 3:52 PM
OLDSMOBILE88
  • 12 POSTS
right i can understand that..i looked at every hose i could see.top and bottom,and couldnt find nothing. but your right there could still be something i might have missed..and im sorry but what do you mean by fuel trims?. like the connections for fuel lines and stuff? cuz i had to replace a couple of them when i changed the fuel pump.
Nov 7, 2010 at 4:57 PM
JDL
  • 16,098 POSTS
As far as vacuum leaks, it could be a gasket, somewhere. You need a scanner that shows live engine data to see fuel trims.
Nov 8, 2010 at 8:51 AM
