1994 Oldsmobile LSS car wont start
14,200 MILES • 6 CYL • FWD • AUTOMATIC
MYLES74
  • 19 POSTS
i have a 94 oldsmobile 88 royale lss and it will not start..but it will start wiuth starting fluid for about 2 seconds then it cuts right back out..i put a fuel pump and main cumputer in it and still did not fix the problem..im think camshaft sensor or crankshaft sensor..im hoping camshaft. any idea? car is driving me crazy
Oct 29, 2010 at 8:13 AM
WRENCHTECH
  • 20,760 POSTS
Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
Oct 29, 2010 at 8:32 AM
