2002 Oldsmobile Intrigue secondary air injection
2002 OLDSMOBILE INTRIGUE
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
WIEDZMIN
i have a engine light on in my 2002 olds intrigue. i checked the code and there is problem with secondary air injection system. i replaced the pump, hose assembly and the relay and still the light is on and the same code came out. what else could be wrong. i took it to the mechanic but he couldn't come up with anything
Oct 14, 2008 at 2:42 PM
DOCFIXIT
  • 18,828 POSTS
Did you clear code after repair?
Oct 15, 2008 at 6:35 AM
WIEDZMIN
yep, several times
Oct 15, 2008 at 12:25 PM
DOCFIXIT
  • 18,828 POSTS
What is code P0xxx
Oct 16, 2008 at 8:19 AM
WIEDZMIN
it's P0410
Oct 17, 2008 at 4:10 AM
DOCFIXIT
  • 18,828 POSTS
Is pump motor comming on can you hear it? if not check for voltage to pump. If pump runs t and there are no leaks then a blockage may have occured.
Also check air shut off valves apply vacuum if it does not hold replace most common cause of P0410
Oct 17, 2008 at 8:25 AM
FGTJBB
I had the same problem. In addition to the air pump, you may need to replace 1 or both of the 2 solenoid valves on the exhaust manifolds. When moisture gets into this air injection system it ususally ruins the valves as well as the pump. Also, there is a kit (upgrade) available for the pump air intake that will prevent moisture in the future. The valves were about $240 each and the upgrade was about $50.
Nov 6, 2008 at 2:27 AM
DESUMP
[quote:8f27309ce7="fgtjbb"]I had the same problem. In addition to the air pump, you may need to replace 1 or both of the 2 solenoid valves on the exhaust manifolds. When moisture gets into this air injection system it ususally ruins the valves as well as the pump. Also, there is a kit (upgrade) available for the pump air intake that will prevent moisture in the future. The valves were about $240 each and the upgrade was about $50.[/quote:8f27309ce7]
Does anyone happen to know the part numbers for the valves, I have a 2002 Olds Intrigue that is having the same problem, and the AIR pump has been replaced 2 times in the last year.
Mar 22, 2009 at 6:42 AM
